View Poll Results: Are T-5 tailshaft housings the same between cable and electric driven speed sensors?
Yes
66.67%
No
0%
Not sure
33.33%
Voters: 3. You may not vote on this poll
WC T-5 Question: Confirm or Deny
Old Oct 4, 2009 | 07:39 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Are the T-5 tail shaft housings between the cable driven and the electric driven speed sensors the same?
So far I've found one that's different but I want to be sure before I go through the effort of trying to find a different tailshaft housing. It looks like the electric one uses one very similar to the 700-R4 sensor that I just removed from the car. This cable one is DEFINITELY much smaller than the one that I had in the 700-R4 that I just removed so I'm just trying to make sure.
Old Oct 5, 2009 | 01:15 PM
rjmcgee's Avatar
Re: WC T-5 Question: Confirm or Deny
The T5's I've seen have been the same cable or electric. But I haven't seen them all. I took a NWC T5 out of an 83 and put it in an 87 Bird. Pulled the cable drive out of the tailshaft and reinstalled the speed sensor.
Old Oct 5, 2009 | 07:08 PM
mos68x's Avatar
That's what I was hoping for but I found a pic of one that had a unit that looked like the 700-R4 sender, which I know won't fit in mine. I'm not that worried about it now since I decided that it would be better for me to just buy the Dakota Digital Converter with a new sender.
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
327IROC85
Sep 23, 2015 12:11 AM
J.C. Denton
Sep 21, 2015 04:23 PM
DARKmj16
Sep 9, 2015 04:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
