1989 rs transmission problem HELP
Old Oct 7, 2009 | 09:49 PM
new2thirdgen's Avatar
Car: 89 camaro rs
Engine: v-6 soon to be v-8
seems like when the car gets hot the trans shifts funny.This happens only when hot. it shifts fine when cold but when it gets hot it seems like it slips into the gears or maybe it just skips 2nd and 4th then reverse sounds real rough. Today the reverse and forward seemed like it didn't want to move at all after the car was running for 20 min. I checked fluid and it was clean and didn't smell burnt and was full. While i was checking the fluid i heard a noise and it turned out it was this vacume canister that is located on the drivers side next to the radiator. I think the canister was suctioned together and then released when i was under the hood .could this be coincedence. After it happened i shifted the car in reverse and it moved fine then in forward also. keep in mind i only rolled a few feet. prior to this it barly made it to where i parked it.. can anyone help?Also I hope i dont lose this tread last time i placed and never seen where it was
Glowsock
Jul 24, 2025 03:15 PM
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
kyleb24
Aug 15, 2015 08:24 AM
