t5 swap questions
Old Oct 13, 2009 | 12:35 PM
86maroresto's Avatar
Car: 86 iroc z28
Engine: 383 stroker, vortec heads
Axle/Gears: 3.73's
t5 swap questions
I recently bought what i believe is a complete t5 swap for a auto 86 camaro. I bought the entire set up which includes the t5 tranny, clutch, pressure plate, flywheel, pedals, upper console and boot, shifter, bellhousing, and hydraulic linkage. Ive been looking at other threads before i go to put it in to make sure i have everything before i start. I saw that some people say you need an extension for the driveshaft but some others dont mention it in the installation. I was wondering if that was necessary and if there is anything else i would need besides a piolt bearing. Thanks.
Old Oct 13, 2009 | 01:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: t5 swap questions
The auto and manual are equipped with the same drive shaft.
JamesC
Old Oct 13, 2009 | 06:10 PM
Car: 86 iroc z28
Axle/Gears: 3.73's
so i wont need anything else besides the piolt bearing????
Old Oct 13, 2009 | 06:27 PM
JamesC's Avatar
Something always seems to crop up, though you appear to be covered. Depending on what's in the trans, you may need to swap the drive and/or driven gears to make the speedo rear correctly:
https://www.thirdgen.org/forums/tran...ve-driven.html
If you're not sure what gear ratio the rear is, check the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
