small t5 leak from bolt on driver side of trans.
Old Oct 14, 2009 | 05:04 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Hi,
I was replacing the speed sensor on the t5 in my formula when I noticed a very small leak from the bolt near the top of the transmission case on the driver side. It looks like a torx bolt. I don't know what it holds. Should I try to tighten it and see if that does anything, or do I have to remove it and replace a seal inside? The leak is very slight, just enough to make the edges of the bolt wet with trans fluid, but not enough to cause drip down the transmission case. Any suggestions would be greatly appreciated.
Old Oct 14, 2009 | 06:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: small t5 leak from bolt on driver side of trans.
Originally Posted by Saculia
I was replacing the speed sensor on the t5 in my formula when I noticed a very small leak from the bolt near the top of the transmission case on the driver side. The leak is very slight, just enough to make the edges of the bolt wet with trans fluid, but not enough to cause drip down the transmission case. Any suggestions would be greatly appreciated.
Though I'm **** in such matters, I suggest this is one to leave alone.
JamesC
92projectcamaro
Dec 8, 2015 12:25 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
