Rear swap question?
Old Oct 14, 2009 | 09:09 PM
dare20's Avatar
Rear swap question?
How far off is the LT1 caprice rear compared to the factory third gen 10 bolt? I'm trying to see how easy a complete LT1 engine, trans, and rear swap will be before I start. I know about the engine and trans however I'm not to sure about the rear.
Old Oct 14, 2009 | 09:14 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear swap question?
The rear end would require a LOT of special fabrication to work, since the suspension is as different as night & day.
Old Oct 15, 2009 | 07:00 AM
big gear head's Avatar
That's right, it would be a big job making the Caprice rear end work in the 3rd gen. None of the suspension is the same and the F body has a special center casting that works with the torque arm.
Old Oct 15, 2009 | 07:18 AM
dare20's Avatar
Thank you very much more questions to come we are restyling our pds DARE car from body parts, engine/trans, paint and interior. More questions to come and will post pics along the way
Old Oct 15, 2009 | 09:35 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Even if you could swap the rear, you'd still want a better axle ratio, so you'd still be doing a gear change. Your third gen's axle is plenty strong for the LT1/4L60E combo, but if you're using the Caprice LT1, it has the iron heads, even if it is a police version. Go ahead and do the LT1, but get some aluminum heads, then get a 3.73:1 gear set.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
