Severe Shudder in first and Reverse.
Old Oct 16, 2009 | 01:48 AM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
Hey guys,
I have an 83 Z, 305 5 speed.
When I put it into 1st or Reverse there is a severe shake or shudder, not sure exactly what to call it, until the car starts moving. I do need to change my clutch. Do you think that is the only problem or something really wrong with the transmission.
Also, if I give it a bit more gas bringing the rpms up a bit the acceleration as I let the clutch out is smoother.
Old Oct 16, 2009 | 03:21 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: Severe Shudder in first and Reverse.
Time for a new disc and resurface the flywheel and p/p. Sounds like the marcel in the disc is non existant, which helps with cushion when you first start off.
Pac J
May 17, 2020 10:44 AM
88CamZ
Oct 8, 2015 10:29 AM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
mfp189
Sep 27, 2015 09:25 AM
