new poly mount
Old Oct 25, 2009 | 05:58 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
new poly mount
i have installed a new spohn poly tranny mount into my 700r4 and the car has crazy vibrations now...i have two set of subframe connectors on and the car still vibrates like no ones business..... this is what i have... i didnt come with any "plate" or anything..... what can i do to reduce the vibrations.... thanks in advance...
Old Oct 25, 2009 | 06:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: new poly mount
go back to the rubber tranny mount - the car always has vibrations - the rubber mounts shield the interior from them, the poly mounts often accentuate them
Old Oct 25, 2009 | 06:05 PM
88fastgta's Avatar
Re: new poly mount
i can live with some vibrations but is there a way to reduce it..... ive replaced the rubber mounts three times... i have a built 700r4 and built 355 hotcammed tpi engine and the stock rubber mounts are useless....
Old Oct 25, 2009 | 06:20 PM
toomany's Avatar
Re: new poly mount
Some aftermarket poly mounts are a tiny bit taller than the rubber ones, causing the driveshaft angle to change. I'm assuming the vibration started with the addition of the poly mount, and it changes with road speed. You can try shimming the crossmember down some (lowing the back of the trans back to where it was). Or if you have an adjustable torque arm, adjust the pinion angle. It should be eqaual (but the opposite direction) to the angle of the driveshaft when it comes out of the transmission.
Old Oct 25, 2009 | 07:32 PM
88fastgta's Avatar
Re: new poly mount
nevermind guys shimed it up and feels alot better... thanks again...
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
ynk1121
Sep 12, 2015 12:27 AM
luvofjah
Sep 10, 2015 10:41 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
