89' 700R-4 slipping only in "drive" not any other sequences
Old Oct 28, 2009 | 11:05 AM
iroc2121's Avatar
Car: 1989 camaro iroc-z28
Engine: 5.7L 350 TPI
Transmission: 700R4-shift kit, moderate stall
Axle/Gears: 3.27 Borg Warner
I have a 700R-4 in an iroc and am experiencing slipping in my "drive" sequence. the tranny slips while shifting between 1-2 and 2-3. the overdrive sequence shifts perfect and the first and second gear sequences shift fine even while shifted manually. i'm thinking its just a stuck or gummed up valve but i'm not exactly sure. i was advised to put J&W Trans-x transmission treatment in it to help re-seal and open up the valves but i've heard some bad things about using a detergent in an older tranny? i would prefer to not fry my tranny but am considering a GM certified tranny swap. Should i go with a rebuilt tranny from a certified mechanic or the GM swap if i end up dropping it? any prior experience or suggestions would be much appreciated!
Old Oct 30, 2009 | 05:58 AM
Pat Hall's Avatar
Re: 89' 700R-4 slipping only in "drive" not any other sequences
Hey, since your other thread got locked, I figured I'd reply to this one. I've used Lucas brand trans treatment in mine before with good results. You don't have to worry about draining it out and replacing the fluid either. You can leave it in there and it won't hurt anything. However, I would suggest taking off the fluid pan and replacing the filter. It's always a good idea to put a new filter in, plus you'll be replacing a good amount of the fluid with new stuff once you put the pan back on. Just put a bottle of the Lucas stuff in there when you're refilling the trans. I picked up a bottle of it at Checker Auto Parts. It's pretty common to find at most parts stores. Btw, I agree that the one guy was pretty harsh in his reply. If he wants to play moderator, maybe he ought to become one. Otherwise, mind your own damn business!
Old Nov 1, 2009 | 10:03 PM
Pro Built Automatics's Avatar
If you can "manually" shift it ok, and the shifting in the "D" position causes some slippage, then the main line pressure is down. The easy solution (for now) is to install a .500" main boost valve. This will raise line pressure in the "D" or the "OD" position. I would add the .296 intermediate/reverse boost valve while in there. This will help with the manual 1-2 shifts. You could add the Corvette servo, which in turn will help out 2nd & 3rd gear shifts at all throttle openings. Both of these are easy to do, and will "improve" the overall situation. I have these parts in stock. Dana
Old Nov 3, 2009 | 04:42 PM
iroc2121's Avatar
thank you for the info. also i just found out as of yesterday that now when i manually shift it minorly slips. it the valve is the problem still... how much would you sell those parts for?
Old Nov 3, 2009 | 09:18 PM
Go to https://www.700r4l60e.com/store/prod...&cat=52&page=1 This will give you the .500" main boost valve, .296" intermediate/reverse boost valve, and the Corvette servo. Dana
Old Nov 30, 2009 | 03:51 PM
iroc2121's Avatar
sorry to ask so many questions but transmissions arent my strongest point. haha will replacing these valve, springs, and the servo require me to take the tranny apart or drain it?
db057
Jan 10, 2020 08:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
camaronils
Sep 20, 2015 02:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
