700r4 ?
Old Oct 30, 2009 | 04:12 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
700r4 ?
will a 700r4 from an 84 vette fit my 85 iroc with a carb'd 350? the trans is toast and a replacement is the only affordable option.
Old Oct 30, 2009 | 04:27 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700r4 ?
If it is an origional vette trans, no. A vette trans case does not have a place to bolt in the trans mount needed for an f-body, or any other GM car. If you have access to the trans you are talking about, have a look. If the trans was transplanted into the vette at some point in it life (with a non vette trans) it can then be considered. The vette output shaft is 3/4 inch shorter, and that may cause a vibration. In summary, I would not do it, even if it would bolt in.
Old Oct 30, 2009 | 04:37 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
Re: 700r4 ?
ok thanks. it would have sucked to give up my whole paycheck and then have two useless transmissions.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
