1986 iroc trans? rear end?
Old Nov 5, 2009 | 10:43 PM
mcrotty's Avatar
Car: 1989 Iroc
Axle/Gears: 3:73 9 Bolt
Hey guys, I'm looking at a '86 iroc to buy, and I'm wondering what this car comes with as far as trans [700r4] and how to check if it's got posi without jacking it up. I know it is a 305 tpi car but haven't actually looked at the car yet. Thanks for any info.
Old Nov 6, 2009 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1986 iroc trans? rear end?
The following FAQ, assuming the car isn't equipped with a 9-bolt, will provide some info about about the rear (if the car is an auto, it's a 700R4):
https://www.thirdgen.org/forums/tran...-10-bolts.html
Without popping the diff cover, however, determining what's really there after 20+ years is difficult.
JamesC
Old Nov 6, 2009 | 12:02 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
RPO codes in the glove box and look for a tag bolted to the diff cover that says that it is a pos or limited slip.
Old Nov 6, 2009 | 12:11 PM
Stephen's Avatar
Car: 87 GTA
After 23 years, donn't assume the original RPO codes are correct anymore.
Tount the gear ratio & check for posi action (assuming it isn't dead or blown), just jack the tires up off the ground & rotate them by hand. Count the # of turns of the tires vs the # of turns of the pinion yoke & you can find the gear ration. All without ever opening the rear end & the oil in it dumping out on you, then having to refill it afterwards.
Old Nov 6, 2009 | 10:03 PM
mcrotty's Avatar
Car: 1989 Iroc
All right, so stock with 700r4 and either way on diff, I'll just have to insp. it. Thanks for the tips.
hectre13
Dec 11, 2023 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
