What Differential For the LS1 Swap
Old Nov 6, 2009 | 12:18 PM
souperman28's Avatar
Car: 89 IROC-Z
My buddy and I are swapping an LS1 into his 95 2.8L Camaro. Ive been reading about what diff to replace his old one with and im coming up with nothing. Ive read about the brake lines and the gearing.
What im asking for is what year 4th gen camaro differential will work the best?
Will a 97 camaro rear end work? if it is disk brake and from the Z28?
Old Nov 6, 2009 | 12:25 PM
Car: 89 IROC-Z
Re: What Differential For the LS1 Swap
I ment to say 85 2.8L
Old Nov 6, 2009 | 01:46 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the fourth gen differential isn't any stronger than the later, 28 spline third gen diffs, which you probably have in your 89. It's slightly wider as well so you'll have to deal with that.
Old Nov 6, 2009 | 01:52 PM
Car: 89 IROC-Z
thanks thats good to know. What do you recomend? should i rebuild it with a eaton and some new gears?
Old Nov 6, 2009 | 02:07 PM
naf's Avatar
naf
There are some threads here on beefing up the 10 bolt rear end. You'll have to run the math, determine your needs and desires and decide whether to upgrade what you've got or invest in alternatives.
Old Nov 6, 2009 | 02:24 PM
big gear head's Avatar
The '85 rear end is going to have 26 spline axles in it. If you are going to do a 4th gen swap then you probably want to get a rear end from an LS car, not the LT1 car. I understand that the LS cars had the Torsen differential and the LT1 cars had the Auburn. The Auburn isn't worth the swap. If you want to build the rear end that you have then get a set of 28 spline axles and an Eaton Posi.
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
EduardoRonaldo7
Sep 8, 2015 01:28 PM
E Rod
Aug 28, 2015 05:17 AM
reiderz iroc
Aug 13, 2015 04:57 PM
