T56 clutch slave
Old Nov 9, 2009 | 11:53 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
T56 clutch slave
Swapped the T56 into my 89 T top car, the clutch doesnt want to depress. Anyone have a clue? I am assuming that it is the clutch fork not on where it is supposed to be? I will try again tomorrow and pull the trans back out if i cannot get it to work.
Never had this problem before on my LT1 car.
Z
Old Nov 10, 2009 | 12:43 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: T56 clutch slave
Z
The clutch wont depress if the master rod is fully extended... is it compressed at all down there? I cant imagine it wouldn't be.. but who knows?
Old Nov 10, 2009 | 12:52 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, i loosened the slave from the trans and the master is still not going in at all. Any idea?
Old Nov 10, 2009 | 01:01 AM
Car: 1992 Camaro RS
The rod from the slave is compressed into the trans and is in the pocket in the clutch fork, though?
Old Nov 10, 2009 | 01:06 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yep, it was, i removed it to see if it would let the pedal move in, it didnt. Weird as hell. Stiff as can be like something is wrong with the master.
Old Nov 10, 2009 | 01:13 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Anyone have a clue?
Old Nov 10, 2009 | 02:31 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Can you compress the slave rod back into it by hand? I've seen them get hyd-locked when pumped out of the car, but usually compressing the slave rod will release it.
If not, you might try removing the line from the slave and seeing if you can pump fluid from the master? The Master may just be bad or need rebuilt? How long was the master/slave out of a car before you got them?
Old Nov 10, 2009 | 06:18 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, had to pull the trans back out, the damn fork was not on right. CRAZY, never had it happen before and i have done my fair share of T56 installs.
Now the SOB has a grinding noise when it is disengaging the clutch. Shimmed it as far as possible and it helps, but if i go further than 3/4 clutch to the floor, it makes a damn crazy noise.
Sucks, but it works great besides the noise, so i will live with it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
