It clunks when I slow down.
Old Nov 10, 2009 | 02:05 AM
3rdgenred's Avatar
Car: 6.7 Powerstroke
Okay,
So when I slow down from driving about 35-40 mph, I hear alot of clunking noise coming from what seems like the rearend. It sounds to far back to be anything from the tranny. Anyone have any thought on what it might be instead. Tranny shifts good and well. Shifts fine if I just leave it in park or if I shift it from 1-2-3-D. I'm running a 700R4 btw. Thanks
-3rd
Old Nov 10, 2009 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: It clunks when I slow down.
I'd eliminate the trans mount first (and do a visual inspection of the underside of the car), then go from there if necessary.
JamesC
Old Nov 27, 2009 | 10:31 PM
Rags91RS's Avatar
Car: 1991 Camaro RS
Engine: 5.0L 305 TBI (L03)
Transmission: TH-700R4
Could be a worn U-joint. A worn U-joint can "clunk" when the transmission down-shifts when you are slowing down.
Old Nov 28, 2009 | 11:07 AM
Untamed Z's Avatar
My guess would be a u joint as well. IIRC a broken tranny mount will "clunk" as soon as you floor it, not when you decellerate.
Old Dec 5, 2009 | 05:55 PM
Pro Built Automatics's Avatar
The 700R4 has a common 3-2 downshift clunk, but this does not sound like it is going from 3rd to 2nd yet at that high of a speed. Check the above mentioned possible problems.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
Ragtop Man
Sep 12, 2015 12:23 AM
