T56 griding when clutch is in
Old Nov 11, 2009 | 11:44 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Well, i am dumbfounded. The car would not start, or push start, then i found that it would start if the clutch was not to the floor. I had my buddy tell me his T56 in the 95 Z28 did the same thing so he shimmed the slave out. I shimmed mine as far as possible and it still does it. I can shift at half clutch or so, but more than 3/4 it makes a grinding/clicking noise.
Was worse before shimming, but the clutch and pressure plate are brand new. It is in my 89 RS. This trans shifts perfect, like butta. Got the trans for 300$, but i use my old bellhousing that works fine..
Any idea would help.
Old Nov 11, 2009 | 01:24 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 griding when clutch is in
Is this a straight LT1 T56 conversion, or a T5-bell+adaptor? What Clutch/PP are you running?
Old Nov 11, 2009 | 06:03 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
Which pedals did you use? 3rd or 4th gens?
Old Nov 11, 2009 | 10:59 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
It is a all LT1 conversion, stock replacement clutch and PP from Fort Wayne clutch.
I am using the 3rd gen pedals, didnt think it would give it cause to make noise.
Old Nov 12, 2009 | 08:11 AM
miner's Avatar
Car: 88 Iroc-Z
Transmission: T-56 Manual
Axle/Gears: 3.23 10 bolt
My car was doing the same thing. Not as bad (I was able to start it with the clutch in all the way...barely) but the same type of thing. It's pulling the pressure plate too far making the pressure plate hit and rub against something. I shortened the master cylinder rod and now it's perfect. How to do it is near the end of the t56 swap sticky.
Last edited by miner; Nov 12, 2009 at 08:12 AM. Reason: forgot a couple of words... =/
Old Nov 13, 2009 | 12:14 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i have seen the shortening thing, dont know if i will do it soon, but i will work with it the way it is for now.
Old Nov 16, 2009 | 08:45 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
4th gen pedals will fix it too, i just went through that a couple months ago on my swap
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
