B&M converter lock-up
Old Nov 16, 2009 | 12:35 PM
TJ07RK's Avatar
Car: 1986 Camaro Z28
Engine: 305 Carb
Just installed the B&M Converter lock-up on my 86 Z. I have a few questions. 1st what speed is a good one to set the lock-up at? and 2nd my transmission is still acting weird. It is shifting at 2600-2800 rpms no matter how hard or soft I mash the throttle. It will not kick down either???? I have a idea that the TV cable is not adjusted right, what do you guys think????
Old Nov 16, 2009 | 01:50 PM
Guest
Guest
Posts: n/a
Re: B&M converter lock-up
I can't advise on your second question, but try to get it to lock up at the lowest speed where it doesn't surge as you cruise along. Depending on your cam, gearing and so on, you may be able to lock it up as low as 25 mph. This would be with a 3.73:1 gear, of course. With a stock 350, and 3.08:1 gearing, 30 mph and 830 rpm isn't out of the question.
Old Nov 16, 2009 | 03:01 PM
TJ07RK's Avatar
Engine: 305 Carb
Well right now I have a 305 Carb and 2.73 gears.. I was think 35mph but was not sure. Just don't want to mess anything up..
Old Nov 16, 2009 | 03:24 PM
Guest
Guest
Posts: n/a
35-40 mph sounds reasonable to me for that combo.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
