86 V6 Trans mate to V8?
Old Nov 16, 2009 | 02:01 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Will this 1986 700R4 trans bolt to a 1986 V8? I'm trying to understand what the trans out of the 1986 V6 Camaro works with....thank you!
Old Nov 16, 2009 | 02:03 PM
Guest
Guest
Posts: n/a
Re: 86 V6 Trans mate to V8?
There are adapter plates, but your 700 will not survive the torque of a V8.
Old Nov 16, 2009 | 02:27 PM
Sandslot's Avatar
Engine: LB9
Thank you! So, there is a big difference in a 700R4 for V6 than a 700R4 for the V8. Sounds like the adapter plate won't do much either since the torque capacity of the trans is different. Can you confirm?...and thank you for taking the time to repond.
Old Nov 16, 2009 | 03:23 PM
Guest
Guest
Posts: n/a
confirmed. Since you'll be hunting, hunt for '87-'93 700R-4s, they're much better than '82-'86 700r-4s. The version you have is easiest to avoid by noticing how the bellhousing has 2 bolts level at the top, while the V8 design is peaked at the top. '87-up versions have the auxillary valvebody inside the pan, which you should drop before purchasing, to verify there are no metal shavings or anything in the pan. These best 700r-4s will attach to any Chevrolet V8 that is commonly swapped into these cars. 4x4 truck versions cannot be installed, so avoid those.
Old Nov 16, 2009 | 03:55 PM
Sandslot's Avatar
Engine: LB9
Thank you again...I learned a bunch! If you know someone in Michigan looking for a V6 700R4 Camaro trans, let me know!
Hawk312
Aug 22, 2017 08:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Hello, Michael
Aug 20, 2015 03:19 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
