transmission may be shot
Old Nov 17, 2009 | 10:13 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
well i was driving along in 5th, i down shifted to 4th and it felt strange so down shifted into 3rd and it got stuck there.
i was told that maybe it was a synchro that busted loose and got jammed in there. so i am going to take my consul apart so i can take a better look at the trany.
but i want to start looking for a new transmission too. the trany has to come out if i rebuild the one i have or if replace it so im thinking of replacing it.
so finally to my question what is the stock 5 speed manual trany from a 84 camaro v8 and is there any other transmissions that will bolt into place without modifying other things. or was the same transmission used in other cars.
also will a stock transmission work with a 350 that i may swap in later.
Old Nov 18, 2009 | 01:57 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: transmission may be shot
You have a non world class T5, the 88 to 92 T5s are world class and handle more power and are better built. That is what you need.
I could sell you mine, but i wont ship, sorry.
Old Nov 18, 2009 | 08:02 AM
endo666's Avatar
Car: 84 Camaro
how much i may be very interested in this.
Old Nov 18, 2009 | 11:22 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Id take 250$, it is the trans and shifter only.
Old Nov 18, 2009 | 07:02 PM
endo666's Avatar
Car: 84 Camaro
is there a tranny that will bolt up to a 305 and a 350 that will handle the power from a built 350
Old Nov 18, 2009 | 07:38 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, i had this T5 behind a 350, but the trans that is rated to handle real power is the T56 6 speed from a94-97 Z28/SS or TA/Formula. Those are what i have now and they are great having a deep rear gear and a 6th gear in the trans.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
