replacing clutch disc
Old Nov 20, 2009 | 11:03 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
well i am pulling my trany this weekend. hopefully. i want to replace the clutch disc and presser plate. what should i use as a replacement. is there anything else that i should replace at this time. by the way i have a 84 V8 with a T5.
Old Nov 20, 2009 | 11:08 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Re: replacing clutch disc
Throw out bearing and pilot bushing. make sure that your flywheel is resurfaced also or the new clutch will not last very long.
Old Nov 20, 2009 | 11:13 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Everything RWB said
Old Nov 20, 2009 | 11:37 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
I also agree and make sure the fork is in good condition as well. .
Old Nov 21, 2009 | 03:40 PM
endo666's Avatar
Car: 84 Camaro
what size clutch disc do i need.
Old Nov 21, 2009 | 05:15 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
if it's just a street car , good quality stock should be fine . stay away from china junk . good luck .
Old Nov 21, 2009 | 06:02 PM
endo666's Avatar
Car: 84 Camaro
but which size diameter do i need.
Old Nov 21, 2009 | 06:14 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
The dia should be 10.4", 26 spline. When you pull the tranny, I would suggest you remove the tranny from the bellhousing first. Doing so will allow you to reach the top bolts on the bellhousing alot easier.
Old Nov 21, 2009 | 06:33 PM
endo666's Avatar
Car: 84 Camaro
yep i removed the tranny today and left the bellhousing. thanks for the other info
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
novaderrik
Aug 10, 2015 12:44 PM
rsrmoore
Aug 7, 2015 08:44 PM
