advice on flywheel and clutch
Old Nov 22, 2009 | 11:10 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
i am replacing my transmission and am also replacing the flywheel, clutch, and pressure plate. i am also looking at doing a 350 swap at a later date and would like to reuse what i can so i want to purchase products that will work now and later
the stock flywheel is relatively light. what would you recommend as a replacement for the stock. a 15lb or a heaver 30 lb. here is what im looking at http://www.summitracing.com/parts/ZZZ-50-6516
i also need a clutch and pressure plate but i read that the hydraulics may not be strong enough to disengage a high performance clutch. but i want a higher performance replacement then stock. here is what i am looking at. will it work.
http://www.summitracing.com/parts/ZZZ-30009/
Old Nov 23, 2009 | 09:47 PM
endo666's Avatar
Car: 84 Camaro
Re: advice on flywheel and clutch
bump. looking for help so i can get parts to get my car back together.
Old Nov 24, 2009 | 04:24 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
have you maybe got a chance to weigh the stock flywheel?
on the 350 swap, it depends if you are doing a 1-piece or 2-piece rear main seal block.
also your 84 T5 is probably a non-worldclass T5, meaning it will grenade with anything over 240lbft put to it over some time..
Old Nov 24, 2009 | 09:29 PM
endo666's Avatar
Car: 84 Camaro
i have no clue if i will be doing a 1-piece or 2-piece rear main seal block.
does anyone know what a stock flywheel weighs.
devilschariot
Feb 25, 2016 03:08 AM
Stangski09
Nov 14, 2015 01:27 PM
el_muerte
Sep 16, 2015 12:01 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
