Pros and Cons 2004r Vs.700r4
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I'm looking for the cold hard facts on what good and bad about the 2004r and 700r4 transmissions, in stock form.
so far this is what I've got
700r4:
Pro:
overdrive, low first gear, removable tail-housing, torque arm mount, low first gear, plenty of cores available.
cons:
big jump from first to second, finicky TV cables, no WOT 4th gear.
2004r:
Pro:
smaller jump from first to second, higher overdrive, and WOT 4th gear IIRC.
cons:
no torque arm mount, pan drop to change speedo gear, finicky TV cable.
anything I'm missing?
Thanks-
Eric
700r4:
Pro:
cons:
2004r:
Pro:
cons:
Thanks-
Eric
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Pros and Cons 2004r Vs.700r4
700r4:
Pro:
cons:
700r4:
Pro:
cons:
