4th gen T5 to 3rd gen T5 Question.
Old Dec 2, 2009 | 08:43 PM
zjorvis95's Avatar
Just got me a new project, an 86 TA, 305, with the T5. The trans was shot when I got her. Third gear is chewed up and I am looking at different options. It is going to stay stock, so a T56 swap is not what I want to do. I was going to get a rebuild kit, and go through it, but I came across a 96 camaro with the 3.8 and it is also a stick. The parts house list it is a WC T5, and the clutch also list as a 26 spline. Does anyone know if I can swap my bellhousing and tailshaft over to this 96 T5? I know the slave cyl. is internal on the 96, and im not real sure on the shifter position on the 96 vs. my 86, or if the bellhousing to trans. bolt pattern are the same. I can get it cheap, so if it will work, that would be great!! Any info would be great!!!! Thanks!
Old Dec 2, 2009 | 09:25 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: 4th gen T5 to 3rd gen T5 Question.
Nope, wont work.
Old Dec 3, 2009 | 08:07 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
wont work because 93 and up t-5 use the for style bolt pattern
Old Dec 4, 2009 | 06:29 PM
zjorvis95's Avatar
Do you mean the pattern between the trans and bell housing, or the bell housing and the engine. I wish I could find a WC from a 3rd gen, but I cant seem to locate any around this area. Do you know if an electric speedo can be converted to manual using my existing trans if i can find one?
Old Dec 4, 2009 | 06:43 PM
yes. where the transmission bolts to the bell housing.......... and for the speedoe yes you should be able to swap the drive and driven gear to the new transmission
Old Dec 11, 2009 | 04:57 AM
Ludo's Avatar
Car: T/A GTA & C4 Vette
you can use a adapterplate (advance adapters) wich will compensate for the longer input shaft and Ford style bolt pattern
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Ian Irvine
Sep 4, 2015 08:08 AM
SlowStangEater
Jul 20, 2002 08:58 AM
youcrash
Feb 21, 2002 07:03 AM
