700 r4 stall question?
Old Dec 7, 2009 | 02:49 PM
ficek801's Avatar
Car: 1986 iroc z camaro
Engine: 355
Transmission: 700 r4
Axle/Gears: dont know yet
hey guys.. new on this site.. puttin in a new 700r4 with racing clutches and good shift kit.. my question is can i use a stock stall converter? thanks..
Old Dec 8, 2009 | 10:57 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700 r4 stall question?
You can.
However, stall choice is usually associated with power band of the cam. As I understand it, you want a stall speed close to the starting rpm range of your cam, so for example if your cam is designed to provide a power band of 2500 rpms to 6000 rpms, then you'd want a stall close to 2500rpms. That is for performance, not a necessity.
I had my tranny rebuilt with all the goodies whe I swapped in my 350 - I have no specifics on my cam since I bought the motor complete and used, but I did install a converter from a S-10 which was supposed to give me a higher stall speed (2100?) than the stock stall (1300?) of my original 700R4/305TBI setup.
Also, stall speeds are a guesstimate at best - it all depends on the torque of the motor in front of it, along with other factors too technical for me. So the advertised stall speeds you see are just to give something for comparison basically.
Old Dec 8, 2009 | 11:02 AM
ficek801's Avatar
Engine: 355
good. thanks i will get one that will match my cam than. thanks agian
Vintageracer
Jan 10, 2020 05:33 PM
84 TA NV
Sep 6, 2015 08:02 PM
tonys91rs
Sep 2, 2015 07:07 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Hecubus
Nov 2, 2001 01:28 AM
