700r4 3.73 posi HELP?!
Old Dec 9, 2009 | 06:51 PM
89rs305-DP's Avatar
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
I have a 700r4 tranny and i want a 3.73 posi final drive, but i cant seem to find exactly what parts i will need to buy and where/ how much it will cost to get it installed? Ive searched the forum for quite a while but cant seem to get a definite answer. If someone could tell me what parts i need and give an estimate on costs i would greatly appreciate it.
Old Dec 9, 2009 | 07:43 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: 700r4 3.73 posi HELP?!
for 3.73s youll need a ring and pinion set, an installation kit, i owuld do axle seals while you are in there
motive ring and pinion set approx 180.00
installation kit...........................30-55 .00
axle seals..................................5.00 each
gear oil.....................................8.00(3)
new limited slip diff.........390.00-450.00
installation will run approx 250.00 to 400.00
depending who you have do it
last but not least you will need to change your speedometer gears in the transmission or your speedometer will be off
Old Dec 10, 2009 | 06:57 AM
big gear head's Avatar
I recommend the Eaton Posi and get a GOOD installation kit. Don't buy the cheaper installation kits. They aren't worth the box that they are packed in. Also get a good quality gear, not the bargan brands. Good parts are well worth the extra money.
KO1
16
Oct 15, 2015 05:00 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
6998poncho
Sep 25, 2015 02:56 PM
