gears interchangeable?
Old Dec 22, 2009 | 12:28 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Okay so I'm suposed to pick up a 4th gen 10bolt after work to day with shot gears for a rear disc set up and I just put some 3.73s(its a posi btw) in my car. I was wondering if I could just swap out my gears into that rearend and throw it in my car or would it be better just to convert my rear end to disc? I did a search and could'nt find anything on this too.
Old Dec 22, 2009 | 12:37 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: gears interchangeable?
they will swap. but you will have to set it back up properly. You cant just throw it in.
Old Dec 22, 2009 | 12:41 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
cool, well thats not a problem, I've done both my rear ends and had no problems. Both of them were pretty quiet too. Thanks man!
Old Dec 22, 2009 | 01:34 PM
3rdgenmaro's Avatar
Car: 88 IROC
no problem. I just installed a 95 z28 rearend under my 88 a few months back. Updated it with a set of 3.73s from a third gen rearend.
so is the 4th gen rear you are getting disk brake?
Old Dec 22, 2009 | 01:36 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
yeah its coming out of an ls1 car, but I found out he's got 3.42s so I cant swap in my gears anyways cuz I have 3.73's with a 2seirs carrier, so I think I'm just gonna convert mine over to disc
Old Dec 22, 2009 | 01:39 PM
3rdgenmaro's Avatar
Car: 88 IROC
gotcha. good luck on the swap
Old Dec 22, 2009 | 01:51 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
yeah thanks man, I cant wait
Old Dec 22, 2009 | 02:30 PM
big gear head's Avatar
If you are going to use 3.73 gears that are made for a 2 series on a 3 series differential then it won't work. You will have to use 3 series gears on the 3 series differential. If you want to swap the differential too then that will also be a problem because your '89 probably has 26 spline axles and the later rear end will have 28 spline axles. You won't be able to swap the axles because they are not the same length. The brakes might swap onto your rear end as long as you have the 4 bolt brake flange on your housing. If you have the 3 bolt flange then the brakes won't swap either.
Old Dec 22, 2009 | 02:35 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
I know I cant swap the gears, but I'm just going to do this
https://www.thirdgen.org/ls1reardisc
Old Dec 22, 2009 | 02:55 PM
That looks easy enough.
Old Dec 22, 2009 | 03:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ed Miller fabs the following for an easy conversion:
http://www.flynbye.com/catalog/i30.html
There are other concerns in the swap, however: axle removal, proportioning valve, e-brake, and speedo:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 22, 2009 | 04:56 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
JamesC
Thanks, I'm not worried about it tho.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
