Noobie Rear End Help
Old Dec 27, 2009 | 12:16 AM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Axle/Gears: 2.73 / Stock
I'm totally new to doing rear ends on cars so i come to you all with a stupid question. We have a 87 Iroc with a stock 10bolt rear end. My brother changed the carrier and now the rear end whines like a cat in heat. Could he have put a carrier in thats to big? or would a 9" inch ford carrier for instance fit in anything? Sorry for the dumb questions! New territory for me! Thanks all
Old Dec 27, 2009 | 12:37 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Noobie Rear End Help
If it's whining, the gears are not set up properly. You need to set them up for the proper wear pattern and have the correct backlash between the ring and the pinion. Pinion depth is adjusted by changing the shim behind the pinion bearing. It's just about impossible to remove the bearing to change the shim without destroying it. A driveline shop will have a modified bearing that doesn't need to be pressed on so shims can easily be swapped around. Once the proper shim is selected, a new bearing is pressed on. The shims on the side bearings adjust the side to side position of the carrier. They're a tight fit and usually need a case spreader to get them in.
If you have a 10 bolt, it's a 7-1/2" 10 bolt. Around 86, it was upgraded to a 7-5/8" ring gear but nothing else changed. The carrier (posi) for a 7.5" 10 bolt will work with 7.5" or 7.625" gears.
The GM diffs also come in different series. It will either be a 2 or 3 series carrier depending what the gear ratio is. You can't put 3 series gears on a 2 series carrier. Well you can but you'll never get it installed in the diff.
Parts from a 9" or any other diff that's not a 7-1/2" 10 bolt will not fit inside the 10 bolt.
Rebuilding a diff isn't difficult but some knowledge of what needs to be done and how to adjust the gears for the proper pattern is required.
Old Dec 27, 2009 | 12:50 AM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Thanks a lot! that answered my questions. Are we looking for disaster by pushing about 450 hp (at the crank) through this rear end?
Old Dec 27, 2009 | 01:00 PM
big gear head's Avatar
Stop driving the car right now and fix the rear end. If you haven't put many miles on it then there is a chance that you haven't destroyed the gears yet. Your brother obviously didn't get the backlash set right when he swapped the differential. This is a huge problem and must be fixed right now. Read this and fix it. http://www.nastyz28.com/forum/showth...t=install+posi
The 7.5 will not handle 450 HP if it ever gets traction. This rear end is just too small for that kind of power.
Old Dec 27, 2009 | 03:11 PM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Thanks for the info!. We stopped driving as soon as we heard that sound actually.. i have the carrier back out.. and the gears are still ok thankfully. Thanks for the link and come to find out my brother didnt check the backlash and such. I think ill just pay someone to do it right ... Thanks all
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
