Flywheel balancing?
Old Dec 28, 2009 | 03:40 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Flywheel balancing?
I've been reading some old posts and now I think I'm more confused than when I started!
I'm getting rid of my automatic for a T56. I'm confused on what to do with the flywheel, should I take it to a machine shop and have them balance it the same way as the flexplate from the automatic? Or should everything be good to go right out of the box? Depending on what post you read some say balance it, some say it should be good right out of the box..
Old Dec 28, 2009 | 03:56 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: Flywheel balancing?
I don't think flywheels get balanced, but I don't think it could hurt anything. Be sure the shop takes off weight, as opposed to adding weight.
Old Dec 28, 2009 | 04:07 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Now that I'm looking a little closer at the flywheels.. maybe it depends on the manufacturer? I was looking at aluminum ones, all the Fidanza brand ones say they need to be balanced, other brands like Ram say they're balanced at the factory and ready to install.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
italiano67
Sep 22, 2015 08:42 AM
