t56 ina 3rd gen questions
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
i have read and read all the forums on this now i have some questions maybe i am not seeing
i know i need to get a t56 how ever i want to make sure i have everything esle for the swap
what type of fly wheel do i need one from an lt1????
i know i need a cross member and the master and slave and pedals clutch and stuff
what am i missing....
also mine has a vss on it.... and i want to go after market gauges any how what will i need to do to wire this all up to read the vss or is that impossible...
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: t56 ina 3rd gen questions
If your motor is a 1pcRMS, you can use a stock LT1 FW. If you have a 2pcRMS, you'll need a conversion FW from Centerforce,McLeod,Fridenza.
An Autometer Electronic speedo will read the T56 VSS directly, just wire it directly in.
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Theres a member on here which can install a mech speedo gear so your factory cluster will work, but thats up to you in the route you go.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
https://www.thirdgen.org/forums/tran...-overview.html
1992 Trans Am
Aug 8, 2015 08:16 PM
