poppin in and out of lockup
Old Jan 4, 2010 | 11:42 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
at around 2k in fourth I can hear my lockup engaging and disengaging
what could cause this
need help
thanks
Old Jan 4, 2010 | 11:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: poppin in and out of lockup
If it persistently does it at a range of throttle opening, look at the TPS. It could have a bad spot where the readings are not linear. The ECM would 'think' the throttle was rapidly changing and command 'unlock'.
Check whether the ECM is commanding lockup when it disengages or not, or if it still disengages when the ALDL pins are jumped. If it's past the ECM look at your brake switch, it's only cheap plastic.
seiplentz
Aug 19, 2019 06:02 PM
customblackbird
Oct 1, 2015 04:30 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
illegal87
Mar 29, 2001 07:38 AM
