I need a V6 T5 flywheel measurement
Old Jan 5, 2010 | 06:09 AM
maticulus's Avatar
I'm narrowing down possible solutions to the dualmass flywheel used with the 6-speed transaxle in the Pontiac G6 being swapped into earlier model fwd cars using the 60 degree V6.
I need the flywheel height from mounting flange surface to clutch disc friction surface, and the approximate thickness of the friction surface area for resurfacing.
I would appreciate any help that can be provided with this, as the dualmass flywheel I've discovered is torque limited and will not likely withstand much boosted torque. The flywheel used on the 60 degree motors is what I'm looking for.
Old Jan 5, 2010 | 04:22 PM
Drew's Avatar
Re: I need a V6 T5 flywheel measurement
You'll probably have better luck asking on the V6 forum...
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
