Where is clutch bleeder screw on t-56?
Old Jan 6, 2010 | 05:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Where is the clutch bleeder screw on a 99 t-56? I have a leak which appears to be at either the slave cylinder or the line from the master cylinder where it goes into the slave.. I put a little fluid in it and the pedal came back up and works again but it falls back to the floor again after a few minutes of not being used but you can pump it back up again.. anyway where is the bleeder screw on the slave cylinder? I thought it was in front of where the line goes into it on the side of the tranny but there's no sign of it there..
Old Jan 7, 2010 | 06:29 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Where is clutch bleeder screw on t-56?
The OEM LS1 T56 slave has the bleeder on the top of the slave, about 2 inches above where the hyd quick connect attaches to.
Old Jan 7, 2010 | 08:04 AM
89RsPower!'s Avatar
thanks so much, I didn't look high enough..
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
