TKO 600 from a ford?
Old Jan 13, 2010 | 12:44 AM
MJ1's Avatar
MJ1
i have access to a TKO 600 that is barley used in a ford mustang.
the guy says it is gm splined, gm bolt patern, and all i have to do is remove the shifter, turn it around and reinstall it and its a chevy TKO. is this true?
trans has "ten halfa$$" drag passes on it, the guys words.
he is going to an auto for bracket purposes. hes asking 1200$
Old Jan 13, 2010 | 01:04 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: TKO 600 from a ford?
1200.00......... ID BE ALL OVER THAT........ NEW THEY ARE 2200.00 OR MORE JUST FOR THE TRANSMISSION......... youll need an adapter plate from fortes and you can then bolt it up to a gm bellhousing and will not need to change the shifter
Old Jan 13, 2010 | 08:36 AM
Bangin Bob's Avatar
We have a precise drill jig to drill the GM pattern on the TKO. We can machine the input and retainer to the GM length pilot etc. You should have a safety bell housing probably anyway and it will bolt right up. We did hundreds that way for all kinds of GM cars before Tremec ever offered a Gm TKO. Let me know if I can help. Bob
Old Jan 13, 2010 | 12:04 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
from my understanding the tko is based off of a ford design anyway. agree with badass as well, call mike forte at forte auto parts.....he has a TON of info on this, and the only adater plate spacer that I know of that you NEED to use to run a tko. Call 508-875-0016, tell him you seen info on thirdgen.org. Great guy. worth the phone call.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
bbsr72
Apr 2, 2016 09:12 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
