Which gears for supercharger
Old Jan 13, 2010 | 06:13 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
Hey everyone, my 10 bolt just broke.. i broke 2 pinion teeth off, and not sure what happened..
So since i have to buy gears, i need help deciding which ratio to choose since my car is supercharged. (had 3.73 in it)
Last year at the track i was passing the finish line in 4th gear at about 4000 rpms, and now with the supercharger im worried i will need to hit 5th gear... so does anyone have any sugestions? should i get 3.42s?
let me know what everyone thinks
Old Jan 13, 2010 | 06:53 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Which gears for supercharger
the pinon gear in the 7.5 10 bolt cant take the TQ a eng makes when it's over 400fp. I have a stack of gear sets ripped apart.
had to upgrade to a better rear end.
as for what gear?
what size tire (how tall) are you running now.
3.73's with a 28" tall tire will give you good times.
but then.. you have to baby it out of the Hole.
with 3.42's we still need to know how tall a tire and what type are you using.. it will hold up better.. but not move the car as fast forward.
unless you use more power to the rear end..
what ever combo you do use..and get it to live..
the car will always be faster with a better rear end and a set of deeper gears.. 3.73's /4.10's.. unless you have 800hp
but not knowing how tall the tire is what type of tire
ill take a stab at it..
4th gear 4000 rpm maby = 26" tall tire right now?
just takn a stab at it.. i would go with a taller tire if you have alot of power..more then 400hp.
have a set of factry GM 3.42's cheap.(cheap)
PM me if you like
Old Jan 13, 2010 | 07:18 PM
i have the stock wheels and tires, and im not sure what the height is. i just know i have a 15 in wheel with a 235 60 r 15 size tire
Old Jan 13, 2010 | 08:18 PM
go out with a tape and see how tall they are.. i bet they are 26"
Old Jan 13, 2010 | 09:22 PM
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
235 60 r 15 size tire should be 26.1"
Old Jan 13, 2010 | 09:37 PM
26" tall thats what i was thinking with the info you posted.
i would go with a taller tire.. you will pick up some MPH in the 1/4 to.
if your car has power.. try the 3.42's.. but you would be faster with 3.73.s of 4.10s but need a better rear end. and the taller tire
Old Jan 14, 2010 | 07:36 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
are you talking about buying a new ring and pinion for the 10 bolt with a 427? Its time to upgrade to a 9 inch or 12 bolt. And 3.73 gears i am thinking would be best!
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Numbah-1
Sep 12, 2015 08:57 PM
89fast5oh
Sep 8, 2015 09:55 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
