what torque converter is better 30 spline or 27
Old Jan 16, 2010 | 11:35 AM
tcgmac's Avatar
Car: 88 iroc
Engine: 350 bored .40 reman vortec heads
here is what i have i have the tranny that came out of my 88 camaro that is toast 700r4. just bought an older 700r4 with 90000 miles it has a 27 spline should i use the 30 or 27 the 30 came from my 88 tranny. I am just going to put a vette servo in the used one an hope it holds up for a while. we are going to put 400 to 425 hp to it. thanx to all your great.
Old Jan 16, 2010 | 11:49 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what torque converter is better 30 spline or 27
More splines = larger diameter. Larger diameter = stronger
Old Jan 16, 2010 | 09:53 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
BEFORE you install ANYTHING, put the 30 spline converer on the 27 spline tranny and spin the converter.......
Old Jan 17, 2010 | 09:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Oops, I assumed that would be known but some people don't grasp the concept.
27 and 30 spline converters are not interchangeable without changing other components. If you have a transmission designed for a 27 spline converter and installed a 30 spline converter, it would go on but the splines would not engage and the converter would not work. If you had a transmission designed for a 30 spline converter, the 27 spline converter will not even go on.
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
