200C to TH350 - Dipstick and Kickdown Questions
Old Jan 23, 2010 | 06:29 AM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
I've done numerous searches and wasn't able to find a solid answer, so I'll ask here:
I am swapping my 200C from my 82 Crossfire T/A to a TH350. The 350 isn't installed yet. Here are my questions:
1. Can I use the stock dipstick tube? It appears to fit in the hole nicely, but is it long enough? I see some people buy a Lokar flexible tube. If I have to I will go this route, but would like to use the stock one if I can.
2. Can I use the stock kickdown cable? Will it be long enough? Also, the end of the kickdown cable (that goes in the transmission) has a small loop on the end of the wire, but the bracket on the valve body also had just a small hole in it...so do I need a wire to connect the two pieces through the holes?
Thanks!
Joe
Old Jan 23, 2010 | 10:40 AM
Jrgunn5150's Avatar
Car: 1989 RS
Engine: 5.0
Axle/Gears: 8.8 3:55
Re: 200C to TH350 - Dipstick and Kickdown Questions
On number 1, I honestly can't tell you.
On number two, there should be a little rod/wire thingy sticking up from the VB out to the hole in the top of the case.
Old Jan 23, 2010 | 03:44 PM
Car: 84 Trans Am
Engine: V8 305 4bbl
That's what I thought, but the wire is missing. Where can I get just the wire at? Any ideas? Looks like I can only get them by purchasing another kickdown cable.
Thanks,
Joe
Old Jan 25, 2010 | 11:33 AM
Jrgunn5150's Avatar
Car: 1989 RS
Engine: 5.0
Lower left corner of the page are the detent part's, all start with a 997 part prefix.
https://www.wittrans.com/Schematic.a...0C&Schematic=4
Old Jan 26, 2010 | 02:39 PM
Car: 84 Trans Am
Engine: V8 305 4bbl
Excellent, thank you!
Joe
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
