Is my 700r4 slipping
Old Jan 26, 2010 | 01:55 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have been fighting a problem with my car for a long time. No matter what i do, if i go WOT and letting the car shift the way it wants, i will blow past the redline.
I thought it was a TV cable problem, so i adjusted it numerous time. Im 100% confident thats set correctly.
If the shift points are set correctly with the TV cable, what can cause it to go past the redline. Is it slipping, governer, shift valves, TV plunger thing?
It only does it if i go WOT in any gear (starting off or downshifting) the needle will go past.
I have to constantly watch the tach so i dont go past.
Any help would be appreciated.
BTW my car feels sluggish till about 3K rpm, im thininking that is just a clogged cat, but i guess the trans can be part of that problem.
Old Feb 5, 2010 | 08:39 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: Is my 700r4 slipping
i'm having a similar problem. its fairly noticible form 1-2 and most noticible from 2-3. i cant really watch my tach because i swapped another one in so its a little off. but i can just tell by how it sounds and feels.
i added more fluid and it helped a little bit but still no good
does anyone have any input?
Old Feb 5, 2010 | 09:32 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I have kinda narrowed it down to my governer being screwed up and allowing it to shift way high. I wont know till spring time when i take the car out and replace the governer, but thats what im thinking.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
