t56 swap help, finishing up wireing
Old Jan 27, 2010 | 12:23 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
I have had my swap done for a few years now but I never wired up the reverse light or the reverse lockout selinoid (spelling) or the neutral safety switch. I was wondering if someone could tell me which pigtails to use. I plan to wire the lockout selinoid into the brake light switch so it will allow me to put the car in reverse when i have the brake pedal pressed.
I want to wire the reverse light switch into the existing wireing from my original auto shifter consule but I can't remember wich wires are for the reverse light.
I also want to hook the neutral safety switch into the cluch so my engine won't crank unless the pedal is pressed.
Any help sorting these thing out would be great. Thanks
Old Jan 27, 2010 | 02:36 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: t56 swap help, finishing up wireing
You can search ebaymotors for "T56 wiring" and get the pigtails, or go into your local NAPA and they shouid have them.
Both neutral safety and Rev lights should come into a plug in the center console. Pickup a haynes manual and it will give you the pin out (and color code) for your car.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
