700-R4 help
Old Feb 2, 2010 | 04:50 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
700-R4 help
yes i have a 1984 firebird trans am it came with a 700-R4 but the guy that had it before me cut off the wireing plug that went to the transmission was wondering if anyone knew what wires im looking for and where i might beable to get a replacement harness i have got under neathe the car and looked in a for the wire but itsno where to be found i think he might of cut it closs to the computer or the brain agean im not sure where it owuld be at if anyone could help me thank you right now i have a th50 in it.
Old Feb 3, 2010 | 04:58 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: 700-R4 help
The plug is for the torque converter lockup solonoid as well as a what I would assume is a pressure switch and a temp switch. Don't quote me on those. I don't believe they are anything that would affect how the car drives.
I 'm going to assume you have a cable driven speedo, otherwise there is another set of wires that goes to that as well.
Old Feb 3, 2010 | 05:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700-R4 help
There's nothing in that harness you need if you have a TH350.
Old Feb 3, 2010 | 06:42 PM
Engine: 383 stroker
Transmission: th350
Re: 700-R4 help
yea its a cable drivin speedo and what im planning on doing is putting back in the 700r4 the th350 is nice but hell on the hightway so wanting to go back to the 700r4
Old Feb 4, 2010 | 01:49 AM
TZFBird's Avatar
Engine: 327
Re: 700-R4 help
The wires come out of the loom right behind the drivers side valve cover. Since you have a 383 the air injection tubing should be removed I would think. This will give you more room to look, but I'd think the wires were cut off there.
Going through some diagrams I found. Not sure if you're going to have the same colors, but it's some to check for.
TCC solenoid:
LT BLU - signal
TAN/BLK - ground maybe
I wasn't able to find anything for the other two wires in the harness. I honestly can't tell you for sure what they do.
Old Feb 4, 2010 | 04:30 PM
Engine: 383 stroker
Transmission: th350
Re: 700-R4 help
that give me a starting point to look for i haft to pull the engine anyways this week cause i bought a new aluminum 350 block and have it at the shop now getting bord and channeled
Brendan
Feb 20, 2003 02:14 PM
mystikkal_69
Car Audio
Dec 8, 2001 07:20 PM
FIRECHICKEN
Dec 4, 2001 08:56 PM
ADMZ24
Aftermarket Product Review
Apr 26, 2001 02:40 PM
kidpunkr
Jul 28, 2000 07:52 AM
