T56 help, 87 gta trans am
Old Feb 4, 2010 | 05:55 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Im about to swap my 700r for a t56 and just want to clarify that im doing this right with the parts i need. Just tell me if any parts are wrong, dont need them, or if i need another part i forgot to list.. thanks!
First off its a 1987 GTA Trans Am, with a 383 stroker and has an 02 camaro ss rearend (if that matters).
1. LT1 Flywheel
2. T56 Clutch/pressure plate
3. Pilot Bearing
4. Release Bearing (throw out bearing)
5. T56 Bellhousing
6. T56 Transmission (duh!)
7. 4th Gen Master/Slave cylinder setup
8. 3rd Gen Manual Pedel set
9. F body conversion crossmember
10. New transmission mount
Am I fogeting anything? Also what is a good place to buy the conversion crossmember? I have longtube headers so i need some clearance. Thanks
Old Feb 4, 2010 | 06:10 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T56 help, 87 gta trans am
deja-vu...
Please try using the search...
There's a sticky at the top of the forum.. Here's another that's still active from just a few days ago..
https://www.thirdgen.org/forums/tran...?highlight=T56
LilHot
South Central
Apr 13, 2026 11:46 PM
jharrison5
Aug 19, 2015 05:53 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
