ugh... stuck between 3.42 or a 3.27. need feedback
Old Feb 10, 2010 | 09:28 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I'm looking for a new rear end for my 1991 Trans Am convertible. It has the stock garbage 2.73 and I'd like to replace it with something better. It also has the 700r4 auto transmission and a 305 TPI. What do you guys think would make the best of the car? I'd like better launches but comfortable highway cruising as well. This car is gonna be close to a daily driver in the warm months. So its either 3.42 or 3.27 (or something very close). What do you think? Thanks!
Old Feb 10, 2010 | 09:33 AM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Re: ugh... stuck between 3.42 or a 3.27. need feedback
I have the 700r4 with 3.23 (i think) and its great. spins the tires in first gear and again in second gear when i punch it. The previous owner might have done something to it though, I am not sure.
Old Feb 10, 2010 | 09:36 AM
Engine: LB9
Thanks for the quick response! Yeah you might have a shift kit in the transmission, and you have a 355... I have the lowly 305 lol.
Old Feb 10, 2010 | 09:52 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I would suggest using 3.45,3.42 just to get the car rolling easier. It would be better if you had a manual trans but it will still help.....
matts86cam's Avatar
Engine: crate 355
Transmission: 700r
i actually havent driven it with the 355 yet, hopefully get it started for the first time tonight, the 305 had 170 k miles and still performed pretty well.
Old Feb 10, 2010 | 03:44 PM
Drew's Avatar
What can you find cheap? 3.23 vs 3.42 you're not going to feel much difference. I'd avoid 9 bolts like the plague. Nothing against them except the complete lack of aftermarket support, and the expensive PBR disc mounting brackets. Well, that and the complete lack of aftermarket support. I'd look for a 91-92 10 bolt with 3.23 or 3.42 posi and PBR discs, second choice would be a 91-92 10 bolt with 3.23 or 3.42 posi and drums, then I'd start looking at 4th gen rears, followed shortly after by rebuilding your existing rear end with a 3-series posi carrier, new gears (of your choice), and new bearings. Truth told rebuilding your existing rear end, while admittedly pricey, is probably your best bet. Because, when you're done you know it's all new. Any used rear end is probably going to probably have been abused and the stock carrier in most of these cars isn't rebuildable.
Old Feb 10, 2010 | 04:54 PM
Car: '88 Trans Am
Engine: 5.7L TPI
2.73 swap to 3.23,3.27 or 3.42 will definately feel a difference..
I swapped a 2.73 rear for a 3.23 rear the car went from 15.0 to 14.7
I encourage you to find a rear end from a TPI 305/5spd or get a rear end from a 4th gen then you get larger brakes,better gear ratio and a better LSD unit....Sacrifice is rear wheel offset,you have to run 4th gen spaced wheels out back.....
Old Feb 10, 2010 | 05:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I've done 2.77 to 3.27 and then 3.27 to 3.42 and i felt a difference each time but surprisingly the 3.27 to 3.42 swap felt the best. Track performance did pick up with each gear as well.
I'd suggest 3.42's. Great highway cruising still with great acceleration feel.
Old Feb 10, 2010 | 05:28 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
If highway cruising is a requirement, lower is better and thus I say 3.2X.
My car is pretty peppy in 3rd with my 3.42's, but I can't comment otherwise as 1st was shot and it wouldn't stay in 4th on the highway.
Old Feb 10, 2010 | 05:36 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
When in doubt gear it out!!
I daily drive my 3.73s with a non-overdrive turbo 350. Even on the highway and interstate. I think you'll be okay with any lower gear if you have OD and a cam that likes that particular rpm range.
Old Feb 10, 2010 | 06:45 PM
Engine: LB9
Thanks for the feedback guys!
It seems that people are leaning towards the 3.4Xs....
Well I found a 3.45 in northern mass for sale for what seems to be a decent price. I'll see if I can talk him down a bit further since the drive will be far for me. And as for aftermarket support (what Drew mentioned)... who cares? If the unit works fine, I don't plan on doing anything to it... MAYBE bigger brakes in the future but that's it. And anybody know what I should look for when opening up the diff cover? If anybody has pictures of a worn posi verses a good posi I'd love that so I know what to look for. Thanks!
And I'm considering getting a 3.2X since I see them for sale everywhere, that is if I don't find a 3.4X for a decent price. The 3.2Xs seem to almost grow on trees.
Old Feb 10, 2010 | 10:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i really like the 3.42s in my car,highway cruise is about
2800-3000rpm,right in the thick of the torque curve of
my engine combo
I'd check that 9 bolt over real good,of the 3 i have had
every one had a badly worn posi-if there is fine metal
dust in the oil the posi is worn,will damage the bearings
if ran long enough with contaminated oil
If you find a good 9 bolt,install a drain plug in the
cover and change the oil every year or so
the 1990-'92 3rd gen rears have upgraded axles and
those 28 spline axles can be installed in earlier rears
if the matching carrier is used. 4th gen uses the same
ring +pinion and same size carrier as 3rd gen,though
a torsen carrier is used on '98-up.
Old Feb 10, 2010 | 10:47 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I went from 3,43's to 3.73's. Felt a big diff! Went side ways with the 3.43's then went crazy with the 3.73's! Good highway drivability. Hell i'm gonna be selling the whole rear if you want to go a lil lower gears.
Old Feb 11, 2010 | 07:19 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
What cars came stock with a 9 bolt 3:27 set up. Thats what was in my 1982 trans am when I bought it.
Ed1LE
Sep 30, 2018 09:14 AM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
JSDaddy189
Sep 26, 2015 03:50 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
