how to Hook up torque con. lock up?
I'm removing the computer to run a different set up from fast ez fuel injection. I will have to run a conventional distributor and a separate lock up switch for the o.d. on the trans. I'm running a first fuel injection intake on a 383. How can i get the lock up working automatically like with the stock ecu without opening the trans. I don't want to run it manually and it works as is so i figure i should be able to wire something up externally to work with the internal wiring on the trans. Any help appreciated.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Ragtop Man
Sep 12, 2015 12:23 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
