?s on speedo gears, went from 2.77 to 3.23
Hi all,
I need help on what gears I need and where I can buy them. I killed my 2.77 rear end and replaced it with a new one that is 3.23. My speedo is wrong obviously. Can someone tell me what I need to buy and where so my speedometers is correct again? Thanks a million.
I also got 2 more questions that are not so important as the above.
1. I put new gear oil in the rear end (don't remember name), it came from autozone and said limited slip additive not needed. Should I add some anyways? I'm hearing some weird noises, can limited slip make any noises because I didn't add the additive?
2. My 89 Iroc does around 14sec @ around 101 mph is that too much power for the standard BW 9 bolt? Cause I am worrying that I will kill the new (way used) rear end. My father told me not to worry, he said I killed the old one because it had a leak I had no gear oil in it. What you guys think?
Thanks a million again!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: ?s on speedo gears, went from 2.77 to 3.23
1. I'm hearing some weird noises, can limited slip make any noises because I didn't add the additive?
http://www.transmissioncenter.net/sp...n_______va.htm
1. Yes.
2. No.
JamesC
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
