9 bolt axle vs 10 bolt axle (spline)
Old Feb 16, 2010 | 07:12 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Are they the same? I searched and can't find info on 9 bolt axle spline's. I got a 9 bolt in my 88 iroc z. I got a 2001 10 bolt given to me out of a SS. I'm about to buy a 89 10 bolt open diff axle. (3rd gen)
Ok my question.
I know 10 bolt LS1 parts minus axle's will swap into 10 bolt 3rd gen. I know I need 28 spline axle's are my 9 bolt axle's 28 spline and will they swap into a 89 10 bolt?
Old Feb 16, 2010 | 07:59 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 9 bolt axle vs 10 bolt axle (spline)
Why don't you keep the LS1 rear end and install it? It's probably in better shape..
Old Feb 16, 2010 | 08:18 PM
TORN's Avatar
Car: 88 IROC-Z
I don't want my wheels to stick out. Isn't the LS1 rear like the LT1 that it's 2 inches longer? I want 3rd gen stock axle length
Old Feb 16, 2010 | 08:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, forthgen rears are wider. Your 9-bolt has 28-spline axles. IIRC, nothing internal from the 9-bolt will swap to a 10-bolt. For example, the 9-bolt has different axle lengths from side to side.
JamesC
Old Feb 16, 2010 | 08:46 PM
TORN's Avatar
Car: 88 IROC-Z
Well I may but I was reading on here that just a small number of late model 89 axle's where 28 spline (it's open diff). So I will need to see what I have and that's why I asked encase the 10 bolt I can get is 26 spline axle's.
dbrochard
Oct 3, 2015 12:43 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
