Tcc lockup question
Old Feb 17, 2010 | 10:44 PM
bubba20189's Avatar
Tcc lockup question
I just finished my v8 700r4 swap. My car was orignally equipped with the t5 and the transmission dosent shift crisp like it used to in my truck if i buy the tcc lockup kit from summit will it fix this problem it lags when it shifts any help would be greatly appreciated thanks
Old Feb 17, 2010 | 11:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Tcc lockup question
you do need to buy a tc lockup system, it needs that. But, also your convertor only locks in 3rd and overdrive when cruising. if it was shifting good before and not now...sounds like you might have to throttle valve (detent) cable out of adjustment. Sounds like the pressure is too low, don't continue to drive too long like this a it will burn up the clutches.
Old Feb 17, 2010 | 11:27 PM
bubba20189's Avatar
oK also my tranny crossmember can i fabricatm my t5 crossmember or would it b betterr to go get one from the junkyard?
jklein337
Sep 19, 2018 06:23 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
redmaroz
Aug 16, 2015 11:40 PM
