14 Spline V-8 T5?
Old Feb 19, 2010 | 01:05 AM
gtopat's Avatar
Engine: LO5
Transmission: 4L60
14 Spline V-8 T5?
Here's an interesting one for you...
I picked up a T5 off of CraigsList to do a swap in my Camaro.
I ran a check on the tag, the code 1352-062, refers to a 84 5.0 trans.
Now, I was an idiot and didn't pay attention when I picked it up and now I noticed it has a 14 spline input. Both the sticker and the metal tag on the trans case have the -062 number, which points V8, but the input shaft points to V6. Is it possible he just switched the tags and screwed me over? What trans do I have?
Thanks.
-Pat
Old Feb 19, 2010 | 10:03 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: 14 Spline V-8 T5?
As far as I know, 27 spine was for a V8 and 14 was for a V6. I never heard of a 14 in a v8 at all and I am sure there isnt even a clutch to make it work anyways. Hope that helps.
Old Feb 19, 2010 | 03:10 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
it is a v6 trans, the v6 clutch MIGHT work on the v8 flywheel but im not sure.
You can buy one at autozone and just return it if it wont work.
You can try clutches for trucks like an s-10 or a 1500 might work.
Old Mar 1, 2010 | 02:04 PM
TDwatts's Avatar
i have run into the same issue. i have a t-5 with a 14 tooth spline but all records show it is for a v8. you can get a clutch kit for an s-10 or even a 11 inch clutch kit from an astro van. just sacrificing the durability of the v8 gears.
i personally didnt want the issue so i found myself a 27 tooth t5. but... i would still like to find this out for resale of my extra t5.
codeysabatini
Nov 10, 2015 04:07 PM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
