Bracket
Old Feb 20, 2010 | 09:51 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Bracket
Can some one recommend a bracket for my tv cable. I have an 86 camaro with an edelbrock carb and i have the corrector for it i just need a bracket.
Old Feb 21, 2010 | 05:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Bracket
I used this one: http://www.summitracing.com/parts/EDL-8030/ It's a very nice chromed bracket, and it's very sturdy - doesn't bend with TV cable pressures like the el cheapo Spectre jobs.
I had to drill one extra hole in it - see how it slides for adjustment? I had to drill one extra hole for the slider on the TV cable to get it just right. But haven't had to readjust any in 3 years now - nice clean sturdy unit!
Old Feb 21, 2010 | 07:11 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: Bracket
I have the same bracket only mine is nickle plated. Its a nice bracket, even has a hole for the throttle return spring.
Too bad im ditching my when I swap to LS1
Old Feb 21, 2010 | 11:05 PM
xbox07's Avatar
Car: 86' Z28
Re: Bracket
Any chance i could get a picture of it installed?
Old Feb 22, 2010 | 07:25 PM
Car: 1992 RS
Engine: Carbed 350
Re: Bracket
I can get ya a pic of mine tomorrow (tuesday).
Old Feb 23, 2010 | 04:12 PM
Car: 1992 RS
Engine: Carbed 350
Re: Bracket
OK - there's a few pics in my Photobucket for ya.
In the first pic - you see 3 bolts, and there's a 4th hiding behind the valve cover bolt in the pic. The two lower bolt holes are the ones I had to drill to get my TV cable just right. I just lined across the two existing holes, and drilled two new ones about 1/2 inch forward.
There are small brackets that actually hold the cables, that bolt onto the large bracket piece - these slide via those bolts and holes in the big piece - loosen the bolts, and slide to adjust. I couldn't get mine to slide far enough foward (the TV cable slider) - thus the new holes drilled. Hope that makes sense.
This link says "Item doesn't exist" - just scroll down to see - there are a couple there:
Edelbrock Throttle Bracket
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
