Rearend help
Old Mar 1, 2010 | 09:00 AM
bubba20189's Avatar
Rearend help
I have a 1991 rs and i just finished the v8 swap( had 3.1 t5) i drove it and i got the one tire fire. I was wanting to kno if i could go to the junkyard and get a rearedn with limited slip and what it would have to come out of to work any help would b great i wanna try and go today
Old Mar 1, 2010 | 09:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rearend help
Some food for thought:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 1, 2010 | 09:16 AM
big gear head's Avatar
Re: Rearend help
I recommend a new Eaton Posi. What gear ratio do you have? If you have a 3.23 to 3.73 gear then the Eaton will work great. You will be much happier with it than an Auburn or most other differentnials. Anything that you find in the junk yard is going to be weak or worn out. It's not a good idea to get 7.5 differentials from the junk yard. If you find a LS1 Camaro then you could use the Torsen unit from it, but I would not use antything else that is used.
Old Mar 1, 2010 | 05:43 PM
danandamy's Avatar
Car: 86 Camaro
Re: Rearend help
Congrats on getting the swap done. What did you wind up putting in it (350,383 etc.)? Good advice already has been given on what you can do, just keep in mind it's still a little 7.5" rear end and no matter what you do to it, it's still weak so I wouldn't put a whole lot of $$ in it.
Dan
Old Mar 1, 2010 | 07:34 PM
bubba20189's Avatar
Re: Rearend help
Ended up goin with a mild 350 im buildin a 383 roller motor right now but overall it was a very easy swap did it in 9 hours
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
