Hawks 4L60E swap crossmember?
Old Mar 2, 2010 | 04:24 PM
vorteciroc's Avatar
Top Answer: 1
Has anyone installed a Hawks maximum ground clearance 4L60E transmission crossmember? Or have photos of one installed?
I'd like to see if this crossmember will work with my 700R4 and SBC... or see if i can modify it to fit.
The 700R4 and (93-97) 4L60E transmissions look externally the same and the crossmembers look the same.
I'm thinking possibly this transmission crossmember is only intended for use with a Gen III/ IV engine swap (different engine mounts) and may possibly change my driveshaft angles.
Can anyone point me in the right direction?
Old Mar 2, 2010 | 09:41 PM
vorteciroc's Avatar
Top Answer: 1
Re: Hawks 4L60E swap crossmember?
Hmm... I guess a better question would be; can anyone think of a reason why a 4L60E transmission crossmember intended for a 82-92 F-body would not work if a 93-97 4L60E trans is a direct bolt in swap?
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Elliswon
Aug 10, 2015 12:33 PM
