rear end question
Old Mar 7, 2010 | 10:04 AM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
rear end question
I just bought a 95 z28 six speed rear end with 3:42 i think.. I'm going to put it in my 91 rs. How will I get my speedo to work after I swap rear ends? And do I buy the 90-92 e brake cable? ive read through a lot of the posts and i'm still not 100% thanks also will the disc brakes fit on my stock 16 rims?
Old Mar 7, 2010 | 10:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end question
Most of your questions will be answered in the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
The discs will fit your wheels.
JamesC
Old Mar 7, 2010 | 10:28 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
Couldn't find anything on the speedo working. I heard after the swap, my gauges will not show the new rpm and right mph, any info on that? thanks
Old Mar 7, 2010 | 10:37 AM
JamesC's Avatar
From the FAQ:
Any third- or fourthgen. While a fourthgen rear is a direct bolt-in, it'll be 2" wider or a bit less per side (note the link below for more info about width). Also, take note that if the gear ratio is changed in a swap, for example 3.08's to 3.42's, the speedo won't read correctly unless the transmission's drive and/or driven gears are changed.
I could help with the gear(s) if you were running a T-5. Since you're not, a call to the following company would no doubt get you set-up.
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Mar 7, 2010 | 12:29 PM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
thank you, I didn't see that somehow.
"Before calling try to have tire height, rear end ratio and drive gear tooth count if possible."
Do you know what my gear tooth count is? I know the other two.
Old Mar 7, 2010 | 12:35 PM
JamesC's Avatar
You might check the stickies at the top of the page.
JamesC
Old Mar 7, 2010 | 12:37 PM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
right i will thanks for the help so far
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
