Backlash and contact pattern...
Old Mar 6, 2010 | 02:32 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
Hi guys. Please take a look to this picture with my contact pattern. I think, it´s really nice. I bought a ring/pinion-kit from richmond gears. They said the minimum backlash should be 0.010". My service manual says between 0.004" and 0.006". At the moment, the backlash is 0.008". What do you think about that ? What should i do ?
http://www.bilder-hochladen.net/files/1eer-2f-jpg.html
Old Mar 6, 2010 | 03:16 PM
big gear head's Avatar
Re: Backlash and contact pattern...
I can't get the pictures to download.
Old Mar 6, 2010 | 03:22 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Doesn´t work this link ? ::
Old Mar 6, 2010 | 03:38 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Looks ok.
92 pontiac GM service manual: Backlash says between, 0.13mm and 0.23mm (0.005 inc and 0.009 inc) for all new gears.
I just took another look at the pic, I have them a little more centered if possible.
I also thighten the E break a little, by checking the contact pattern.
Here is the pic
Old Mar 6, 2010 | 04:34 PM
That picture looks good. It should work fine. I still couldn't get the link to work.
Old Mar 7, 2010 | 10:45 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
I changed the pinion shims 12 times to get this contact pattern. Every time, i adjust the backlash, too. Finally, i used the stock shims on the right side and on the left side from the carrier to get the right backlash and this contact pattern.
Today, i´ve seen, the service manual says, i should´nt use the stock carrier shims ! Why ?? I don´t understand ?? The shims looks great ! Will i´ve got any problems with these stock shims ????
Thank you !
Old Mar 7, 2010 | 02:30 PM
As long as the stock shims are in good shape and the bearing preload is right then they will work fine.
gord327
Oct 3, 2015 01:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
indygene
Sep 26, 2015 11:21 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
dimented24x7
Sep 17, 2015 06:58 AM
