Vibrations
Old Mar 12, 2010 | 11:17 AM
95camaro3800's Avatar
Vibrations
I just finished installing a mild 400 into my 86. I noticed shortly after starting it, that I put the wrong balancer on (huge one, from a 350). Today I replaced it with the smaller one that the engine came with, however now there is a very obvious vibration, which was nonexistant before.
Now after looking at the flexplate, it looks identical to the one from the 350, no external weights. I'm thinking if I get a new flexplate for it, externally balanced, it should cure this vibration issue, since it will be in synch with the balancer, correct? Just wanted a second opinion before i start pulling stuff apart again.
Old Mar 12, 2010 | 12:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Vibrations
yes. the 400 has an externally balanced damper and flywheel.
Old Mar 12, 2010 | 12:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Vibrations
correct
Old Mar 12, 2010 | 12:14 PM
Re: Vibrations
Perfect, just wanted to make sure.
Thanks guys!
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
